FieldPoint Family
Which FP module can read resistances?
Hello community,
I have a digital encoder or index for a gas meter that provides electrical resistance 10x every revolution. I'm not very savvy on how the electronics work exactly, but I understand that it's a very common way to measure this type of thing.
My question is what Field Point module is capable of counting these resistance measurements and how to set up the counter if need be. I do have LV2014SP
Message 1 of 11
(6,583 Views)
It seems strange that you are trying to read in a resistance on a counter task. An encoder usually outputs a voltage. What is the encoder that you are using?
Message 2 of 11
(6,554 Views)
Message 3 of 11
(6,547 Views)
It doesn't look like NI sells any FieldPoint devices anymore. What are you trying to do? I'm sure there's a device currently being sold that can do that.
Message 4 of 11
(6,524 Views)
well I already have FP quad510,DO400,AI110s hopefully it's either the quad510 or the DO400.
All I'm trying to do is use a digital counter to count pulses coming from the index.
Message 5 of 11
(6,519 Views)
I think everything is wired up to the Quad510 properly, but still not getting any readings.
Could it be because the time stamp is not updating in MAX?
Message 6 of 11
(6,514 Views)
