I am currently stuck with LV6.1.
My host program is currently using Datasocket to read and write data to and from a Field Point 2010 system. My controls and indicators are defined as datasockets. In FP I have an RT loop talking to a communication loop using RT-FIFO. The communication loop is using Publish to send and receive via the Datasocket indicators and controls in the host program. I am running out of bandwidth in getting data to and from the host and there is not very much data. The RT program includes 2 PID's and 2 filters. There are 10 floats going to the Host and 10 floats coming back from the Host. The desired time critical loop time is 20ms. Data is moving back and forth from Host and FP several times a second without regularity(not a problem). If I add another float each direction, the communications goes to once every several seconds(too slow).
Is there a more efficient method of transfering data back and forth between the Host and the FP system?
Will LV8 provide faster communications between the host and the FP system?
Chris
