FieldPoint Family
What is the max PID loops possible using cFP 2120 RT @ 200 msec loop rate?
I am using cFP 2120 RT Controller for controlling multiple outputs. What is the maximum number of PID loops possible in a single cFP 2120 RT Controller at a loop rate of 200 msec?
Valliappan.M
(6,695 Views)
Hello Valliappan,
Here are some benchmarks that NI has run to characterize the performance on various real-time hardware. This can give you an idea of the maximum performance achievable with Compact FieldPoint. I recommend that you read the entire document to understand how the benchmarks are performed. There's also a link to the code that was used to achieve this benchmark.
Note that these benchmarks are best-case scenario. That is, once you add more code to your application, your performance will be affected.
Gerardo
(6,678 Views)
