Hello, I currently have 24 identical Fieldpoint banks running the same application. Each bank consists of a FP2015, a 422 relay module, a AI-110 analog input module, and two TC-120 TC modules. These modules have been installed for about two years now. These banks use the NI Time Service provided with the software.
Just in the past week however, I have had two banks that started incorrectly reporting the date stamp on a regular basis. Data is logged to file every 5-10 minutes (depending on the setup). Everything will be working fine at one scan, and then by the next scan the date will have changed to the year 2028 in the module. If I reset the FP2015 module (either through Fieldpoint explorer or by powering cycling), the next scan will again have the correct time and date. However, the errored scans with the 2028 date remain in the file, which messes up the software app when it is trying to calculate elapsed time. This has been happening now since last Friday (six consecutive days), and sometimes happens more than once per day. It also appears to happen at random times, that is, the two modules don't error at the same time as the other, and they error at different times from day to day.
One of these same modules did this once about two years ago when we were first bringing everything online. We just thought it was some install glitch because we rebooted the module and it never happened again (until now). We have upgraded from the A series firmware, which had a time service problem. I believe we currently have an E series firmware installed.
Any idea what could be causing it to jump to a date of 2028 (it is always the same date in 2028, starts with July 1 2028 I believe)? Why are only these two modules effected? Any help would be appreciated.
