10-12-2006 07:56 AM
10-13-2006 08:44 AM
10-13-2006 09:14 AM
Thanks for the response Chris.
We disabled the XP firewall completely in previous tries. Even if this were the issue, would not the firewall block our communications with the other relay modules that are on the same FP ethernet module?
We can set the values using MAX directly. On the PC that works, I can also bring up MAX and watch the values change as our OPC client changes them. On the PC that does not work, the values never change as we set them from our OPC server. This is only for the PWM modules.
Jay
10-16-2006 10:03 AM
10-20-2006 08:42 AM
Chris,
I had already removed the complete install of any NI software. After uninstalling I even deleted the "\Program Files\National Instruments\" folder. Reinstalled everything and still the same. That was the last thing I tried before sumbitting messages to this forum.
It does not work from "Server Explorer" either. Had tried that already.
Jay
10-23-2006 10:29 AM
