FieldPoint Family
Upgrade to 8.5 from 8.2 write ini file wipes ini
Hi I recently upgraded to labview 8.5 and when the code was converting everything seemed fine, but now everytime i run my simple VI to write to an ini file the inifile gets wiped!  I cannot understand it.
The path on the fieldpoint cfp-2100 is c:\test.ini and it simply goes through a for loop to index all the ini names and values,
starts off by opening config data.vi, then goes into ta for loop and writes all the info, then jumps out and closes the config data.vi.
I'cant see why it still reads from the INI file fine at teh start of the program, but just this writing to the INI file throws a wobbler.
any advice appriciated
thanks, Chris
(5,642 Views)
(5,641 Views)
