06-06-2007 04:32 PM
Thanks for your suggestions but I can easily exclude all of the above mentioned problems. I have problems with a serial RS232 device directly connected to the cFP-2020 and I am using only VISA and serial library functions that are provided by NI. It also seems that this error only appears occasionally which speaks against a wrong resource name.
@ching P. wrote:
Hi Olaf,
This error can be due to several different causes. One of the most common reasons for this error is that you are not using a proper resource name for your instrument.
Other reasons for that error are described in the following KnowledgeBase Articles:
Buffer Size Error -1073807298 With TCP/IP Communication
Error -1073807298 When Using a Third Party USB-Serial Adapter
Error -1073807298 with a Third Party Instrument Driver
Please take a look at these documents and let me know if you have any additional questions.
06-06-2007 04:55 PM
06-06-2007 05:18 PM
I am not at work but from memory I think it was VISA 4.0 and RT-serial 3.1. The ones that came with 8.20. I updated everything with MAX to the latest versions available on my PC. What I do not know is, if the same versions are used for compilation of the LV-code on the PC before deploying. I could not find out against which library versions a certain vi is compiled.
@ching P. wrote:
Hi Olaf,
What version of NI-VISA are you using? You can find this under the My Systems >> Software Tab in Measurement and Automation Explorer.
According to the first link I provided, this error could be a result of using an older VISA driver.
06-08-2007 09:31 AM
Hi Olaf,
If you installed the latest drivers from your PC onto the cFP controller, your
VI should be pulling from the same VISA library.
One other thing to check is to make sure you are using the correct baud rate
for your instrument and that you have the appropriate wait between sending
commands to your instrument. It could be that the instrument is not able
to handle commands as fast as you are sending them. Since you only error out sometimes, this may
be the culprit.
Please let me know if you have any additional questions or concerns.
06-11-2007 11:13 AM
Thanks for your further suggestions. With some minor tweaks to the latest proposed version/idea here it got the code running again! As far as I can tell it seems to work stable except for some conditions under which the fieldpoint is very busy but it doesn't crash the code, it only corrupts data for one or two read cycles which is OK. I still plan to improve the whole software performance-wise to avoid these situations as best as possible. Thanks again for all who helped in the last weeks/months with contributions to this discussion.
@ching P. wrote:Hi Olaf,
If you installed the latest drivers from your PC onto the cFP controller, your VI should be pulling from the same VISA library.
One other thing to check is to make sure you are using the correct baud rate for your instrument and that you have the appropriate wait between sending commands to your instrument. It could be that the instrument is not able to handle commands as fast as you are sending them. Since you only error out sometimes, this may be the culprit.
06-18-2007 08:43 AM
Hi Olaf,
I'm just about to undertake the programming of a MCA8000a, and ran into your recent posts. Basically, what I need to do is to adapt a simple LV application I wrote for another MCA card to use the MCA8000a instead. The application is not time critical, and will ultimately run on a desktop pc under windows. Interoperability under linux could be a marginal bonus, which I could give up for the moment. Therefore, I just thought that writing a minimal driver based on the PmcaDll.dll provided by Amptek was the standard way to go. I think I already have a fair amount of experience in interfacing with odd devices, unpacking funny data structures and protocols and what it takes, but seeing your posts, I realized that building a serial driver from scratch (which would then be portable to linux) might be not that trivial as I thought.
Is there some general word of advice you could give me before I start a dead end? For instance, did you have some success with the amptek dll? What led you to write a lower level serial driver instead (the RT fieldpoint target, I guess)?
Thanks in advance, Enrico
06-19-2007 11:56 AM
A short answer to your question: The reason why we could not use the provided dll is that this cannot be used on the fieldpoint, otherwise we would have done that. Our driver is tuned to what we really need and rather incomplete, so I am afraid that it might be not very useful for you but if you are interested, I can provide you our vi's. Maybe you can improve them and send them back to me later so we can both have a benefit. Please contact me privately if you are interested.
@enrico Segre wrote:
Hi Olaf,
06-19-2007 04:26 PM
