I hope someone else has had this problem and can help. I'm running LabVIEW 8.5 with a cFP-2100 controller and a TPC-2006 touch panel computer. I have a VI running on the TPC that has some numerical controls that pass their information to the VI on the cFP-2100 via shared variables. I'm using an Event Structure with an "Enter" button to tell the VI on the TPC when to write. The VI on the controller monitors and displays those values on my host computer. Here's the problem: when I exit the VI on the TPC, the numerical values are reset to zero momentarily, and then go back to their previous values. I cannot for the life of me figure out what is causing that. I even wrote a simple VI to just write a number to a single shared variable, and it still happens. This is causing problems in the larger VI that I'm trying to troubleshoot. Anyone have any suggestions how to fix this?
Eric
