FieldPoint Family
Toolkit to read the channel of FieldPoint module
Hello everybody
I have one problem,,, I'm programming for a module FieldPoint 1000. But I can not use the function that reads the channel of the module, because I have not installed the Toolkit for this module.
My question is: What toolkit should I install that allows me to use the FieldPoint (to read the FieldPoint channel)?
Thanks for the help
(6,053 Views)
Accepted by diegofernando8891
Hi diegofernando8...,
To use fieldpoint you will need LabVIEW Real-time module and Filedpoint software driver.
You said you use Fieldpoint 1000, what LV version you use? I ask because Fieldpoint 1000 only work until LabVIEW 8.5 and prior.
Best Regards,
Abel Souza
Applications Engineering
Certified LabVIEW Associate Developer - CLAD
National Instruments Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(6,039 Views)
Thanks for your help,
I'm using lv2009. I am going to try with the FieldPoint driverbecause real-time module I have it installed.
(6,035 Views)
Thanks for the suggestions.
Just I have already installed the RT and also the FieldPoint driver on 32-bits LV2009. and I can access the FieldPoint palette functions.
(6,026 Views)
