02-07-2012 09:51 AM
Hello everybody
I have one problem,,, I'm programming for a module FieldPoint 1000. But I can not use the function that reads the channel of the module, because I have not installed the Toolkit for this module.
My question is: What toolkit should I install that allows me to use the FieldPoint (to read the FieldPoint channel)?
Thanks for the help
02-08-2012 07:02 AM
Hi diegofernando8...,
To use fieldpoint you will need LabVIEW Real-time module and Filedpoint software driver.
You said you use Fieldpoint 1000, what LV version you use? I ask because Fieldpoint 1000 only work until LabVIEW 8.5 and prior.
Best Regards,
Abel Souza
Applications Engineering
Certified LabVIEW Associate Developer - CLAD
National Instruments Brazil
02-08-2012 08:55 AM
Thanks for your help,
I'm using lv2009. I am going to try with the FieldPoint driver. because real-time module I have it installed.
02-10-2012 09:21 AM
Thanks for the suggestions.
Just I have already installed the RT and also the FieldPoint driver on 32-bits LV2009. and I can access the FieldPoint palette functions.
