FieldPoint Family
Timestamp not updating in MAX
Has anyone ran into problems with the timestamp not updating in MAX? It will only update after I start then stop the panel.
This is happening on a Quad-510 only, all the other modules in the bank seem to be working fine.
Message 1 of 8
(5,283 Views)
Hey,
Does the correct data show or is it only the timestamps that are not acting correctly?
-Brian J.
Message 2 of 8
(5,256 Views)
I can't tell if the data is showing correctly.
It's supposed to be counting pulses, but i don't see any counts updating.
Having to start and stop to update the timestamp probably resets the pulse count if there is any.
Message 3 of 8
(5,251 Views)
Hey sorry for the late reply.  How are you generating the pulses? If you are still having this issue.
-Brian J.
Message 4 of 8
(5,183 Views)
Hello BrianJ,
No worries about late replies, any help is appreciated.
Pulses are coming from a rotary type index on a gas meter. I thought that it was emitting a voltage when I hooked my multimeter up to it, but that may just be noise in the line or something.
I later found out that it is a resistance type signal generator. Please forgive my lingo I hardly know what I'm talking about lol.
I'm not sure what FP module if any I should be using to measure resistance.
Message 5 of 8
(5,171 Views)
Thanks for the reply.
Can you attach a screenshot of NI MAX of the issue you are coming across? I am not sure what timestamp you are referring to.
Brian J.
Message 6 of 8
(5,152 Views)
It's this one, but I think maybe it just wasn't updating because none of the values were changing.
But I'm going to start a new thread with a better proposed question, hopefully.
Message 7 of 8
(5,034 Views)
Hey,
I would verify if that was the case and keep us updated on the situation.
-Brian J.
Message 8 of 8
(5,026 Views)
