04-10-2010 06:06 PM
Hi, currently i have a solenoid valve (NVZ110) with 24Vdc , "+" & "-" terminals) and I have:
CFP-DIO-550
CFP-AO-200
CFP-AO-210
CFP-AI-112
My question which module should I use to open and close the valve? Also, I couldn't find a tutorial on how to create a simple vi to control this valve using LabView. Does someone have a simple example VI?
04-12-2010 08:18 AM
TuskBoy,
How much current is required @ 24VDC to actuate the solenoid valve?
04-12-2010 06:29 PM
04-14-2010 04:13 PM
Hello thank you for your response. The solenoid valve is normally closed and operates at a current of 75mA. My main concern is the construction of the VI that will send the signal.
Thank you.
04-14-2010 07:46 PM
06-02-2010 04:17 PM
06-02-2010 05:14 PM
Does the solenoid require AC or DC voltage? What vare the oltage and current requirements?
-AK2DM
06-03-2010 11:37 AM
06-03-2010 12:43 PM
Here is the manual:
http://www.ni.com/pdf/manuals/371324c.pdf
The 550 only accomdates DC outputs, that may explain why the valve is not actuating. Hopefully you did not wire a 24VAC source to the 550, it may be damaged if you did.
-AK2DM
06-03-2010 12:57 PM
As an alternative, you could use the 550 to turn on a DC coil mechanical or solid-state relay, whose output contacts could then apply/remove power to you AC powered solenoid.
-AK2DM
