I am in need of some advice/help. I have an experimental setup that requires the rapid opening of normally closed solenoid valves based on a physically measured parameter (wind speed) which I am currently measuring using the compact fieldpoint. I took a look today at various options, and it seems that I may want to look at getting the cFP-RLY-421 along with a connector block. Is this the case? This module acts as a relay switch which when combined with an outside power source will open and close my valves correct? The valves are 24 VDC actuated valves and I am assuming that the relay when connected with the valves and the power source will close the circuit and actuate the valve based on what I am telling it to do.
Also, I was wondering if there was a VI out there that specifically shows a voltage signal being generated for compact fieldpoint control of the 421 relay module? Does any of this make sense?
In short, I just want to control some valves with my fieldpoint and I am just not 100% sure of how to do it. Kind of like turning a light switch off and on, but automatically.......hopefully, someone can shed some light.
Thanks.
Tim
