10-08-2007 07:54 AM
10-08-2007 08:56 AM
Hello rchaoua,
If you are having trouble seeing an unconfigured target in MAX, the issue is
most likely that the Windows Firewall is blocking the default IP address of the
cFP-1804. Please turn off any firewall you may have and then refresh
MAX. You should then see a real-time target with an IP address of 0.0.0.0
under Remote Systems. If you are using Windows XP, you should be able to
turn off your Windows firewall by going to Start >> Control Panel
>> Security Center >> Windows Firewall, under the General tab you
can turn off the firewall. Once you have configured you cFP-1804, you
should be able to turn your firewalls on again.
If you still need assistance seeing the IP address of your cFP-1804, please
refer to this KnowledgeBase
article.
10-08-2007 09:02 AM
10-08-2007 09:29 PM
10-08-2007 09:45 PM
10-08-2007 10:00 PM - edited 10-08-2007 10:00 PM
You are using a X-over cable to connect to the CFP. Is the computer connected to a LAN at all? Perhaps the computer does not have an IP address assigned. Go to a command prompt and type ipconfig and see what comes up.
With a crossover cable, you are basically making your own private LAN. Most computers use DHCP to get their IP address, but on a simple LAN of a point to point connection, there is no DHCP server to have the computer get an IP address. You may need to statically assign those values to the computer's network card before you will be able to see the cFP on the crossover cable.
The blinking red light on the cFP means is is waiting to be configured.
Message Edited by Ravens Fan on 10-08-2007 11:01 PM
10-08-2007 10:19 PM
If the computer does not have an IP address assigned I would like to statically assign one. However, all of the articles I have read make it sound like you pull any number out of the air and that is your IP address. I would like a little more direction than "Set the IP address". Any suggestions? After the IP address I must set the subnet mask once again some thing I would like a little more direction on.
10-08-2007 10:47 PM
10-09-2007 08:59 AM - edited 10-09-2007 08:59 AM
Hi rchaoua,
Do you have NI-FieldPoint installed? Without the FieldPoint driver, MAX
will be unable to detect the cFP-1804. If you need to install the
FieldPoint driver and are using LabVIEW 7.1, 8.0 or 8.2, you can download it
from here.
If you need the FieldPoint driver and are using a different version of LabVIEW,
let me know and I'll be more than happy to help you locate the correct version
of the FieldPoint driver to use.
If you are unsure whether you have the FieldPoint driver installed, expand My
System >> Software in MAX, and if the FieldPoint driver is installed you
will see FieldPoint in the software tree.
Additionally, if your computer has firewalls in addition to the Windows
firewall, that may also be blocking the device from being discovered in
MAX. Make sure all firewalls are turned off as well as any anti-virus
software. On occasion, I have seen anti-virus software prevent devices
from being discovered in MAX.
Please let me know if you need additional assistance.
Message Edited by Ching P. on 10-09-2007 09:00 AM
10-09-2007 09:12 AM
Thanks for the reply Ching. I used the CD to install the FieldPoint SW that occupanied the HW. I am pretty sure the drivers were contained on this CD. I have LabVIEW 8.5, will the link to the FielPoint Driver still work? Any assistance in finding the correct one will be very helpful. In the meantime I will check if the driver is installed.
I have turned off all firewalls but not the anit-virus software (McAffee). I will do that and provide updates this afternoon.
Thanks again.
