I am using . I can’t get a Labview driver for this specific function generator. I try the DG4000. I gives me a signal error and can’t figure it out. Can you please suggest me how to get the Labview for Rigol DG1062 Arbitrary function generator.
Thanks for your answer. I am new to Labview. I have a Rigol DG1062 function generator. I want to triger halfwave sine signal using chanel 1. I want to do this using my PC through the help of Labview. When i search at your catalog you dont have Labview files for Rigol DG1062. But I can see for DG4000. I try that but didnt work. So it is possible to get for Rigol DG1062 ?
You are correct, there isn't a LabVIEW API driver for that device currently. You can still communicate with the device using standard protocols (VISA perhaps), or you can work on developing an API driver for the device (There is a link on the drivers page for doing this here:
