04-18-2007 12:41 AM
04-19-2007 12:52 PM
04-19-2007 06:10 PM
Hi Emilie,
Thanks for your reply. I guess I'll have to do that. My client only had Fieldpoint Explorer 3.0.2 at their site the other day, when I raised it. I am familiar with uploading new drivers to FP through MAX. So I'll just get the latest version of Fieldpoint (are there any limitations with LabVIEW 6.1, and latest version of Fieldpoint?), update MAX, and do it that way. That seems like the best way forward. I assume Fieldpoint upgrades are free?
04-20-2007 10:36 AM
04-29-2007 05:06 PM
04-30-2007 09:07 AM
04-30-2007 04:46 PM
Hi Tommy,
Thanks for your prompt reply.
The spare controller was sent to me already formatted. By this I mean the NI Support Engineer ran the "format disk" option for me, before sending it out. So I had an empty RT Controller to start with.
And while I think of it, I was never actually able to get the "Format disk" option in NI-MAX.
I will get a hold of the ni-rt.ini file and post it today.
05-01-2007 12:28 AM
Tommy.
Attached is the Ni-rt.ini file.
05-01-2007 12:36 PM
[LVRT]-Tommy
StartupDLLs=/ni-rt/system/FPLVMgr.dll
There should be another DLL listed here. This is your problem.
This ni-rt.ini file is updated when you install driver components from MAX to your controller.
You should not need to know what DLLs are in the list, they should just get updated automatically.
Try this work around:
Make sure MAX is closed. Go to your "<National Instruments Directory>\RT Images" directory.
<National Instruments Directory> is probably C:\Program Files\National Instruments.
Extract the attached zip file to this directory. Relaunch MAX and uninstall/reinstall or format your controller and reinstall.
The longer explanation of what was broken and what this zip file fixes:
There are files in the RT images directory that specify what DLLs and ini information is ftp'ed
to your controller when you perform an install from MAX. In older versions of MAX (such as 3.1),
there was a bug where some of the information is parsed incorrectly from the RT images files.
You can look in zip file and see there are places where I added a ';' to the end of the startup DLL
entries because this makes it easier for MAX to parse. This problem is fixed in newer versions of MAX (4.1 and on), but it is
probably easier for you to use this zip file instead of updating your MAX version.
Let me know if this does not fix your problem.
05-06-2007 05:49 PM
That seems to have worked Tommy!
Many thanks for your help!
