FieldPoint Family
Problems with the cfp-AI-100 the signals are out of range but the cfp has the channel connected to 4-20 mA instruments
Problems with the cfp-AI-100 the signals are out of range but the cfp has the channel connected to 4-20 mA instruments, the cfp has been working for 2 years and suddenly the analog input starts to varying from 0-24mA and then those signal goes up to out of range.
(3,003 Views)
Highlighted
Suggest you insert meter to read mA in current loops and verify actual signal levels into AI-100.
(2,999 Views)
i did that, but the problem still is present, do you have another  suggestion to fix this issue. Do you know any procedure to reset the CFP AI-100. How can be sure that the  CFP AI100 is not damaged.
(2,991 Views)
If you have verified with a meter that signals into cFP are correct, then you know problem is in AI-100.  Does problem occur on all channels or just one?
Also suggest that you verify the supply voltage to the AI-100 module.
(2,987 Views)
