FieldPoint Family
PXI 8195: Failed to bring up ethernet device Halt_on_error flag set, rebooting in 3 seconds for retrying
I'm using PXI 8195 with RT. When I switch it on and I try to connect from a host PC (windows xp) I cannot connect: If I connect a screen to the PXI I can read the following message: "Transferring control to user program, MAX system identification: NI-PXI8195-2F11B34D. ..Labview real time single core kernel      Initializing network...." and then it appears "Failed to bring up ethernet device Halt_on_error flag set, rebooting in 3 seconds for retrying". May you help me?
Thank you
Manzo
(6,101 Views)
Hi Manzo
I wold suggest you to use the PXI switches to reset the controller IP address and reinstall the sw eventually.
You can find more information on the PXI 8195's switches on page 2-12 of the PXI User Manual.
Feel free to contact NI Italy for direct support on the controller in case the suggestion I did doesn't solve your issue.
Best regards
Alessandro P. | NI Italy
(6,086 Views)
