03-01-2010 11:30 AM
I'm using PXI 8195 with RT. When I switch it on and I try to connect from a host PC (windows xp) I cannot connect: If I connect a screen to the PXI I can read the following message: "Transferring control to user program, MAX system identification: NI-PXI8195-2F11B34D. ..Labview real time single core kernel Initializing network...." and then it appears "Failed to bring up ethernet device Halt_on_error flag set, rebooting in 3 seconds for retrying". May you help me?
Thank you
Manzo
03-02-2010 03:42 AM
Hi Manzo
I wold suggest you to use the PXI switches to reset the controller IP address and reinstall the sw eventually.
You can find more information on the PXI 8195's switches on page 2-12 of the PXI User Manual.
Feel free to contact NI Italy for direct support on the controller in case the suggestion I did doesn't solve your issue.
Best regards
Alessandro P. | NI Italy
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
