10-26-2005 09:05 PM
10-28-2005 05:23 PM
Hi JFT,
Are you trying to use Remote Front Panels when you get the error message. If yes, you may find this article useful. Also, I did not understand what you meant by "the problems of excessive memory consumption can be avoided, when we used conventional PCs". Are you not using PCs but PXI? Please correct me if I am missing something.
Ankita
11-02-2005 12:34 PM
Hi Ankita, i will read that document now...
I work with a conventional PC and a PXI (8175). The problem is when i try to see the remote front panel thru a LAN, my application and the Remote Panel crashes, and the messages is "Not enough memory to complete this remote panel operation....". So, my question is, if it is posible to avoid this kind of problems? or remote panels are limited to a little apps... My App acquire a lot of data (thru a DSA 4472 daq) and then it process and shows that data without problems until remote panel is activated.
Sorry my english... and thanks anyway
JFT
11-03-2005 03:53 PM
Hi JFT,
Typically with remote panels you want to minimize the data that needs to be updated...all this is mentioned in the article I pointed in my last post. If LabVIEW crashes again, I would suggest that you choose to Investigate Error which will send an error log via email to National Instruments support team. In your email please mention exactly what you were doing before LabVIEW crashed. Once we get the error log, we will send it to R&D so they can investigate the crash.
Ankita
