FieldPoint Family
Modbus and cFP-DI-304 data packet
I’m using a host computer to communicate with the cFP-DI-304 using Modbus over Ethernet.
When the cFP-DI-304 (revision D) is polled, it is returning incorrect data (looks like a timing issue). What is the sequence and data package when the cFP-DI-304 gets polled?  Does the data sequence starts from pin 1 to pin 32, pin 32 to pin 1, or some other combination? Also is the package 8 or 16 bits?
(5,643 Views)
Please post any VI's you have for doing this communication.  Is the cFP-DI module on a backplane with a cFP controller or a communications module?
I'm not familiar with using ModBUS to communicate with individual cFP modules.  The usual method is to use datasockets or shared variables.
(5,642 Views)
The cFP-DI-304 is connected to the cFP-1804. I’m using a host computer to communicate with the cFP-DI-304 using Modbus over Ethernet.
(5,639 Views)
