FieldPoint Family
Is it possible to measure ac voltage using cFP-AI-100?
I have the cFP-AI-100 module.. is it possible to measure ac voltage with this analog input module?
Is there is any specific module?
(3,791 Views)
Hi ELUE,
I will need a little more information to give a good recommendation.  What range of voltages will you be measuring?
Other things we need to consider is what frequency the signal will have, and if we need isolation between the channels.  Any further information would help.  Have a good day.
Brian K.
(3,773 Views)
yes.. i got the readings.. input was within the range[30V]
(3,758 Views)
