07-31-2007 09:36 AM
07-31-2007 09:56 AM
07-31-2007 09:59 AM
07-31-2007 10:22 AM
07-31-2007 11:02 AM
Yes, I want to connect the RTD directly to the module if possible. We are not sure yet if our RTD is of the type that's compatible with the FP-TC-122. It appears that the FP-TC-122 is designed to work with platinum RTDs. Ours may be 10 ohm copper, or 120 ohm nickle. We're measuring winding temp in a 161kv/13.8kv substation transformer. Still trying to learn what type of RTD it will be equipped with. We believe it is 3 or 4 wire, but don't know its resistance yet.
If the RTD is not compatible with the TT-122, can you recommend a transmitter that would allow connection with the AI-111?
07-31-2007 12:02 PM
07-31-2007 01:27 PM
08-01-2007 10:34 AM
08-01-2007 10:47 AM
