FieldPoint Family
Incandescent lamp brightness control - dimmer
For a proof-of-concept project, I need to simulate daylight for day and year cycles. For this purpose, incandescent lamps are OK. Specifically, ten 40W bulbs (~3.5 amps total). They will be off during 'night' and full brightness at 'noon on June 21' and somwhere in between during other 'daylight' hours. So what I think I need is a PC controlled dimmer and a program with two loops one for the day and one for the year.
I searched and found DMX-512 controlled dimmers used to control stage lighting made by Leviton and others. Seems like it would work. Also found some info about rs-232 to DMX-512 conversion and found some manufactured converters but they are pricey.
I have a Compact Fieldpoint system.
Any suggestions of a better way to make a software controlled dimmer? Or if not any guidance regarding the approach outlined above?
Thanks in advance.
Kevin
(5,254 Views)
Cross post, see discussion here:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=391996
(5,247 Views)
