06-18-2008 09:19 AM
Solved! Go to Solution.
06-19-2008 08:30 AM
06-19-2008 01:08 PM
06-19-2008 01:45 PM
Mark and Graziano,
Thank you for your resposnes. I'm checking into it now because it is somewhat perplexing, but the solution was simple. I have the cFP mounted in an enclosure. To wire the ethernet cord through the wall of the enclosure I have wired an ethernet plug to a wall socket. This allows me to connect the laptop via a cable that runs to the wall socket on the outside of the box. On the inside of the box the wall socket is wired to a ethernet plug that plugs into the port on the cFP.
One laptop accepts this situation with no problems, but the vaio connection is dead until I bypass the wall mounted plug altogether and directly wire the laptop to the cFP. Why it works for one and not the other, I don't know.
However, it is up and running so thanks again.
06-20-2008 04:39 AM
06-23-2008 09:56 AM
06-23-2008 09:58 AM
PROBLEM RESOLVED
Thanks to all who answered. The issue was related to the wiring. All is good now.
