FieldPoint Family
How to change time on Fieldpont FP2010 ethernet controller from NI Max?
Recently booted up an old fieldpoint setup for a test. Trying to log some temperatures on the citadel database. But the timestamp from FP is wrong and i can only set the time zone on the controller not the time. Currently using Labview 2011 sp1, fieldpoint 6.0.11. Is there any way i can sync the time with my system?
(3,643 Views)
How far off is the time in the timestamp? Is it just the hours or are the minutes wrong too?
How are you getting the time? Get Date/Time function?
(3,608 Views)
 Thanks for the reply. I'm just creating a new trace on citadel database and exporting it as a text file. Connected to this PC using Fieldpoint ethernet controller FP2010. Trying to measure temperatures and voltage only. For example @7:10 AM citadel database timestamp is showing 3:50 AM. Time setting on remote system tab on MAX is only showing time zone. Running system is a windows xp sp3 with Labview 2011.
(3,606 Views)
