04-02-2009 07:11 AM
lovexf,
Suggest you open up the Configure Attribute.vi and use Highlight Execution to determine exactly where the error is occuring. My guess is that the error occurs in a sub vi named DS Sync Write (Word).vi. Begining to suspect this is a Data Socket problem. You could try writing your own vi that directly uses the datasocket functions. This document goes into advanced data socket a bit more and some things that would keep it from working. http://zone.ni.com/devzone/cda/tut/p/id/4499#toc1
What field point controller are you using?
04-02-2009 08:51 AM
lovexf,
I may have figured this out. As I said before, the Configure Attribute.vi is using a logos datasocket to modify the settings on the cFP. The vi is generating a URL with back slashes. I'm pretty sure that a logos datasocket needs a URL with forward slashes. I found this document. http://digital.ni.com/public.nsf/allkb/B0C5F514A850BF8F86256DAB0047BB98 I've got a call into NI to verify that this is indeed a bug in the FP library.
04-05-2009 11:16 PM
It’s very kind of you to do this for me, now it perfectly done . Communicate with you, I leaned more about the FP.Thank you ,my teacher~~
04-06-2009 06:48 AM
lovexf,
Glad to hear that it is working. Can you tell me which model of cFP you are using and what version of LV you have loaded?
04-06-2009 10:30 AM
