03-29-2009 08:10 PM
Hi,friends
Now I have a problem about cFP-PWM-520, I'd like to change the period of the pluse in labview program ,not in the channel configuration dialog box, is that possible? I have a step motor, it controled by the numbers of the pulse,so in my project, I need to change the speed of the motor by change the period of the pluse, if that possible, how can I do? or what instrument should I need to buy?or something else?
thank you
yours Bluse~
Solved! Go to Solution.
03-30-2009 06:47 AM
Bluse,
You should be able to change this from your program using the Fieldpoint>Advanced>Ethernet Advanced>configure atttribute.vi.
03-30-2009 10:50 PM
03-31-2009 06:45 AM
04-01-2009 12:19 AM
04-01-2009 08:31 AM
I need your help again,now I am trying with that vi you mentioned last time,but when I run this VI,error comes,and I don't know what's wrong with it,here are VI and picture~~the duty can run with no problem,but。。。
04-01-2009 09:25 AM
04-01-2009 02:02 PM
Double check your Fieldpoint path in the purple constant. In the background of your screenshot, you have a weird W character with a horizontal strikethrough rather than a normal backslash.
04-02-2009 06:34 AM - edited 04-02-2009 06:40 AM
04-02-2009 06:35 AM
forget to upload the image~~here
