‎07-28-2008 07:19 AM
‎07-29-2008 09:29 PM
Thank you for contacting National Instruments. If I understand you
question correctly you are trying to figure out how long you will be able to
log data using you cFP-2200 as a Real-Time Controller. As long as
you send the data back to the host machine that you are connected to you will
be able to continually log data. You will need to make sure that you have
enough free space on the Controller if you are storing data. Here is some
information about logging
data on a Compact Fieldpoint Controller. If you have any further
questions on this issue or if I am not understanding your issue correctly
please post back here and let me know. I hope this helps!
‎07-30-2008 08:22 AM
‎07-31-2008 10:53 AM - edited ‎07-31-2008 10:54 AM
It can be difficult to say exactly how many seconds or minutes you can log data
on a cFP controller because it really is possible to set up the controller to
continuously log data for an "infinite" amount of time (or at least
until there is an error, power failure, or something else that would interrupt
the functionality of the controller). The issue is that there is only
128MB of space on your controller so you need to make sure that you are
transferring the data quickly enough before the memory on the board fills up
because that will also stop recording. Knowing how long you have before
the memory on the controller becomes full if you are not transferring the data
to another machine completely depends on how much and the type of data
that you are logging. My recommendation to you if you have a time constraint
of how long you need to run your logging would be to transfer the data off from
the cFP to make room for more data logging. Here is a knowledgebase article that
will explain the different communication methods that you can use to transfer
data. Also here is another link that shows how to FTP
files to and from a Real-Time Controller. I hope this helps!
