04-27-2009 08:24 PM
Hi
How can I change the duty cycle when a signal is generated by the compact FieldPoint module cFP-PWM-520?, I can control the period, but the ON time of the signal is not user selectable in the MAX channel attribute, only period(ms) is shown.
Thanks for your help.
Regards
Peter
04-28-2009 07:26 AM
Peter,
Duty cycle can't be controlled using channel config in MAX. Can only be controlled by writing a value to the I/O. See page 7 of this http://www.ni.com/pdf/manuals/323357b.pdf
04-28-2009 10:29 AM
04-28-2009 10:34 AM
