10-22-2005 01:09 PM
10-23-2005 08:01 AM
Hi Qia,
Are you able to read the correct temperature in MAX? If yes, then you should be getting the same value in LabVIEW too; if you are not, then there's an issue on the LabVIEW side, or more likely, your VI.
Any particular reason for using the Optomux commands directly? Have you tried the regular FP Read VI?
-Khalid
10-23-2005 08:29 AM
Yes,I can read the correct temp.in Max.
I don't wanna use FP Read VI,because it can not configure the FP setting in LabVIEW.
10-23-2005 02:26 PM
