FieldPoint Family
How can i connect FP-PWM-520 8-Channel, 5 or 24 V PWM to computer
Hi
How can i connect FP-PWM-520 8-Channel, 5 or 24 V PWM to computer.
Is it supports for Programmble interface(specially using LABVIEW).
Give me the details to interface connector hardware and software description.
Thankq all
Mahesh.
(2,824 Views)
Hi Mahesh,
It sounds like you are just getting started with using the FP-PWM-520.
Since you are looking for rather general information I would recommend that you search ni.com for 'FP-PWM-520' and you should find plenty of relevant links.
Connection info can be found in the Operating Instructions Manual which is linked off of the Product Page.  More general information can be found on the DataSheet.
As with all other National Instruments products you can easily program and control FieldPoint from LabVIEW.  Don't forget to download the latest version of FieldPoint (currently NI-FieldPoint Version 4.1 for Windows 2000/XP).
These links and any other searches should help you find what you are looking for.
(2,809 Views)
