Hi, I am using cFP-AI-100 to read the current of my system and determine if the current is above the ideal value. Using the field point i was able to achieve the reading of the current; however, I would also like to display the current as a function of time. So i want to display the current in the y-axis and the time(in secs starting from zero) on the x-axis so i see the change of the current (dI/dt).
I tried using the NI Scope but it does not work as i thought it would. Any suggestions?
thanks
Guillermo
