We just purchased an Omega DLC101 Force sensor and are hoping to use Field Point to take the readings. The sensor has the following specifications:
Excitation: 2 mA nominal @ 18-30Vdc *Use only constant current power supplies. DO NOT supply power from non-current limited power supplies
Rated Output: 5Vdc nominal FS
Will the FP-PS-4 and the FP-AIO-600 work to supply power and take the readings?
Also, when programming this in Labview, what would be the best way to convert the readings to show the forces applied to the sensor?
