FieldPoint Family
Having problems with my CFP 2000
Once I download my VI. using file transfer I cannot get the CFP2000 to start running on its own. I still must start with exe.? Which means that I am using the exe. still instead of the memory in the CFP2000. If I unplug the ethernet connection from the computer to the CFP2000, The PAC will lock up. I use Labview 8.0 with 5.0.1 FeildPoint software. Has anyone else experienced this?
Craig
(3,534 Views)
Hi!
   In MAX there's an option, Halt system if TCP/IP fails , in cFP module configuration, have you checked or unchecked it?
   About the downloading of an exe, can you clarify the steps you make to download application in your cFP-2000?
   I actually am using LV 7.1, I hope  there's not much difference with 8.0 you're using....
   Have a nice day!
graziano
(3,530 Views)
