FieldPoint Family
Fieldpoint - How to reconfigured Field point hardware configuration
Respected Sir,
We are using labview version 5.1, operating system windows 95, FiledPoint explorer 1.6,
I would kindly request all to please help to solve how to reconfigured Field point hardware, I am new learner of labVIEW.
When i run Fieldpoint explorer 1.6, in labview 5.1 operating WINDOWS 95 version, i received one command as
A value return from the server is out of the expected range.
The FieldPoint hardware ranges need to be re configured, so they match the ranges saved in the configuration file.
Go to each device configuration dialog and select channel configuration to synchronize the saved configuration with the hardware configuration.
Thanking You
Yours faithfully
M.Viajy
Message 1 of 1
(5,880 Views)
