08-13-2010 06:40 AM
I can´t connect to a fieldpoint FP 2010. LINK and ACTIVE LED are on / blinking, but I can´t connect to the IP-Adress. How can I change the IP-Adress without NI Software?
Best regards
Ralf
08-13-2010 06:42 AM
Ralf,
What version of LabView are you running? The 2010 is only supported up to version 8.5.1.
08-13-2010 06:47 AM
hello,
I´am just working on a computer without LabView because i tried to realise a connection to the FP. A student workung with the FP in his lab told me that he can´t get a connection to the FP. I hoped that I can try this with "ping" or with the help of a browser, ftp or so on.
May be I have to try it an a PC with LabView. I think there is Version 10 installed.
ralf
08-13-2010 06:52 AM
... it is version 9!!
08-13-2010 06:56 AM
ralf,
If you know the IP address you should be able to ping from anywhere on the network. You might also see if the it shows up under 'Remote Systems' in MAX. Even though the newer releases of LV don't support the FP-2010, it should still show up in MAX.
08-13-2010 07:13 AM
It seems to be so that the IP-adress has been changed. I can´t reach the FP.
Ralf
08-13-2010 08:26 AM
I could solve the problem with th help of MAX, it works fine now!
Thank you - Ralf
