12-04-2006 02:36 PM
12-05-2006 06:54 AM
12-06-2006 09:12 AM
12-06-2006 08:36 PM
12-07-2006 07:22 AM
12-07-2006 10:55 AM
Hi un-yah,
I built a simple application that just included a FieldPoint I/O control drop
down browser and a FieldPoint Read. The FieldPoint I/O control drop down
browser worked properly in both the VI as well as in the executable. I
did not do anything other than just build the application. Like
centerbolt, I am interested in knowing if you are running on your development
machine or on another PC. In addition, can you give me the version of
your FieldPoint Driver? You can find this by opening Measurement and
Automation Explorer, expanding the Software tab, single clicking on FieldPoint,
and the version number should appear in the window on the right.
Also, if you get a chance, please run the .exe in the attached file and see if
the FieldPoint I/O control drop down browser is working properly in this
application.
Best of luck on your application, and have a wonderful day!!
10-08-2010 07:13 AM
Ching et al
Any more news and info on this subject ?
I am now seeing the same problem under LabVIEW 2010, the FP IO Point browse dialog
works fine under source code within LabVIEW, but when running an executable, the browser doesn't work
but comes up with an error message, complaining some resources are missing.
Martin
02-15-2011 02:08 AM
Ye solved that problem by using a new versions of NI-visa and NI-serial in order to install the drivers but using an older version of NI-fieldpoint as for some reason versions past version 6 removed the drivers installed by via and serial. (I used NI-fieldpoint 5 series)
Hope this helps 🙂
