10-01-2009 04:18 AM
Hi, we have some problem with FP-TC-J module, sometimes the field point is not viewed (MAX return a message "one or more attributes specified either do not exist.." )
The first time i try to move the module and this work fine, i fixed the module and it's works.
The next day the module have the same problem, i try to move without good results, we try to change the place of the module, but MAx say is not possible (seems this module is not know by the system).
My question is how is possible to know if the module is bad?
thanks to reply.
Solved! Go to Solution.
10-01-2009 04:30 AM
I will add this message thats alternate with the previous:
"empty base or slot".
10-02-2009 03:11 AM
Hi Nicola,
it seems you could have a problem either with your module or with your terminal block.
Are you using the FP-TB-10 terminal block? If so, could you tell me which is the part number and serial number of your FP-TB-10?
Do you actually have an empty slot in the terminal block?
Serena M.
NI Application Engineer
10-05-2009 07:00 AM
Yes i've FP-TB-10 terminal block; the data you ask me is:
PN : 186287C-01
SN : CF5F36
I've just thre module mounted on this board (2 digital output module and 1 TC-J) in the past i've mounted also an analog input module.
Thanks for your answer.
Nicola
10-05-2009 07:39 AM
Hi Nicola,
the FP-TB-10 is designed to reboot itself everytime it detects a new dual channel module since they are hot-swappable (quick flash of the ready light). If there is an empty slot next to a dual channel module (an AI or AO or TC module), the FP-TB-10 Terminal Base may incorrectly detect this dual channel module. Since you have also two digital module, you can put the digital module next to the empty slot and ckeck if this solves the problem.
Let me know if this works.
Serena
10-06-2009 05:43 AM
