05-20-2014 03:49 PM
Hi everyone,
I will be using the FP TC 120 module to measure several temperatures using thermocouples. My question is that if I use FP Read to read the output from FieldPoint IO Point In which corresponds to a certain thermocouple, will FP Read give me an actual temperature reading or just a voltage? If it's the latter, how can I convert that voltage into a temperature? Thank you.
05-20-2014 04:21 PM
It will give temperature.
You just need to make sure you configure the channel for the correct type of thermocouple.
05-21-2014 09:18 AM
Thanks RavensFan!
If you don't mind, I had another unrelated question. If I'm using the PID VI from the PID and Fuzzy Logic Toolkit, is it possible for the VI to output a negative value? For example, if my process variable is above my setpoint, would the VI return a negative value?
05-21-2014 09:28 AM
I think so. But I'm not sure.
Just start playing with it and find out.
