05-27-2006 08:27 AM
05-30-2006 04:05 PM
05-30-2006 04:31 PM
05-31-2006 05:30 PM
06-05-2006 08:10 AM
Travis,
Sorry I didn't get back to you sooner, as I was out of the office.
I was able to create a Tag called ''Some'' and add all of the channels to it, and in Max the Timestamp continued to update.
Some Info:In the previous program that worked with Max 3.2, I was able to create the ''All'' tag by using the automatically created ''All'' Item in Max. On the ''FP Refnum Out" output of the Create Tag.vi, I created an indicator. From that indicator, I created a Local Variable that I then tie to the ''FP Refnum In'' of the ''FP Read(Polymorphic).vi''. I tied an Floating-point array constant to the ''Type'' input of the ''FP Read(Polymorphic).vi''. An array indicator tied to it's output returns the values of the eight channels.
Now, using Max 4,0 and following this procedure as above with the ''Some'' tag I created still does not return any values, even though it looks to be working fine in Max. No errors are displayed by the ''CreateTag.vi'' or the ''FP Read (Polymorphic).vi'' ... it just doesn't return any data.
I also tried substituting the ''FP Read (Float Array).vi'' for the ''FP Read (Polymorphic).vi'' with no luck. I also tried reading the ''Some'' tag with the FP Read Express.vi with no luck, although I can read the tags of individual points just fine.
As for what version of the Fieldpoint Driver, I assume you're asking about FPLVMgr.dll. Mine is dated 11/16/2005. (the previous version, that worked, was dated 6/27/2003)
Thank you for your diligence.
Mike
06-06-2006 02:20 PM
06-14-2006 11:24 AM
