FieldPoint Family
FP-CTR-500 and Frequency Measurement: How to modify it to report the frequency (0-10 Hz) every one minute?
How to modify "Frequency Measurement" to report the frequency every one minute?
The signal frequencies vary from 0 to 10 Hz (see the analog output plot and attached sample data file), so I want record the average frequency every one minute.
Software: Labview 8.5
Hardware: FP-CTR-500
Program: "Frequency Measurement"  --build in and under "NI example finder", It was attached with this message.
Physical wiring: (1) The signal I want to measure to count input 1 (pins 2 and 18).  it is a pulse signal (range from 0 to 1 V, see the plot and attached data file).
 (2) Wire Output 0 (pin 130 to gate 0 (pin 9).   Do com pins 26 and 30 need to wire together?
FP-CTR-5000 was set up in Max based on the program instructions. I have tried different gating pulse frequency, my readings are always "0".
(5,932 Views)
CTR-500 high pulse is >=10V. Hence, it always read your pulse as low. With this low voltage pulse, you must use analog input module, and write a program to read pulse from analog level. You must also make sure that you pulse is not so narrow that cFP loop is not fast enough to capture voltage change.
(5,835 Views)
