04-15-2014 06:42 PM
I have an alicat mass flow controller (MCR). I need to wire for both input and output signal. I have an FI-AI-110 to read in 0-5 V signal and an FI-AO-200 to sent out 4-20mA signal. The alicat 8 Pin mini-DIN-Out is such that pin (4) is analog input signal -4-20mA pin(6) is 0-5Vdc pin (7) is Power in pin (8) is ground. On the FP-AI-110, I wire pin (6) to slot (1), pin (7) to slot (17) and pin(8) to slot (18). I can read the flow reading fine in labview. I then connect pin (4) of the alicat to slot (1) of the FP-AO-200. I cannot sent a signal to the Alicat controller. I think I need to connect both pin (7) and pin (8) of the alicat to the fieldpoint, but though that they should already be connected?
04-15-2014 08:28 PM
I'm pretty sure you need to connect some power source to the V terminal of the module in order to complete the analog output loop.
04-16-2014 07:36 PM
Correction,
On my alicat 8 pin mini din I have the following:
Pin #
(1) 4-20mA primary output signal
(4) analog input signal (4-20mA)
(7) Power in
(8) ground (common for power, communications and analog signals)
These are the connections I was thinking of making using the FP-AI-110 and FP-AO-200. Please see if I am missing anything before i wire it up.
Alicad pin 1 to FP-AI-110 I (in)
pin 8 to FP-AI-110 com
pin 4 to FP-AO-200 I (out)
pin 7 to FP-AO-200 V (sup)
given that no external power is applied to the unit.
