10-31-2007 09:04 AM
11-01-2007 10:46 AM
11-02-2007 06:32 AM
Hi Bob,
I formatted the memory and reloaded the software. The result was the same. It tries to deploy DAQmx Create Scale and fails. Why does this occur now when it never occured before? What changed? How do I fix it?
11-02-2007 07:47 AM
09-01-2011 01:15 PM
Don't feel stupid. I just experienced the same error and your thead helped me resolve it quickly.
Thanks!
05-03-2012 06:10 AM
Hi
Please any help with this error
"Initializing...
Calculating dependencies...
Checking items for conflicts. This operation could take a while...
Preparing items for download. This operation could take a while...
Deploying rt1.lvproj
Deploying BEENS(successfully deployed target settings)
Deploying rt.virt.vi loaded with errors on the target and was closed.
LabVIEW: Failed to load shared library nilvaiu.*:get631:C on RT target device.
Deployment completed with errors"
Even after completed reloaded the software. I am getting this error. please help me.. Thanks
Manu S
05-04-2012 10:51 AM
Hello Manu,
I would recommend making a new thread for this error you are seeing. You are more likely to get responses with a new thread.
Before making a new thread, try loading an example VI onto your controller to see if you can deploy any VIs. Also, try reformatting your controller. Report these results in your new thread, and we will be able to help you out faster.
