10-16-2008 08:16 AM
I am trying to use the advanced datasocket "reset" command to reset my cFP-1808. Look at the images below, if the full url is wired to the write, then the reset works. However, if a DS ref is opened then the reset doesn't. Any suggestions and will this be an issue is I use DS refs to write to IO?
As a side note, why do the cFP-1808 modules ship with firmware version 6.01, when 6.05 was release in 2006? Why after upgrading to 6.05 does MAX report 6.06?
Brian
10-17-2008 05:30 PM
Hello Brian,
I was able to get your VI working in the False case by changing the Mode for DS Open to "Write" instead of "Read/Write". Does this fix work for your program?
Yes, the cFP-1808 ships with 6.01 firmware. I guess along the way of developing newer versions, we decided to just make the updates available online rather than create new discs to ship with the hardware. I don't know if or why one idea is better than the other, or who ultimately made that decision at NI. Also, the download for firmware 6.05 appears to include both 6.05 and 6.06. Might just be something that was overlooked when we upgraded again. R&D churns out those updates and new products!
10-20-2008 07:26 AM
Hi LaRisa,
No, I originally had the write and switched to the ReadWrite since that is what the DS Synch Write uses inside the Configure Range.vi (and deadband and attribute). The module resets are not working either when the DS connection is opened and then written, so it seems like the problem may be in the datasocket layer.
Brian10-20-2008 04:08 PM
