‎10-10-2006 05:11 PM
| Robst - CLD |
| Using LabVIEW since version 7.0 |
‎10-12-2006 11:00 AM
Hi Robts
The FP-RLY-420 Module requires 1.7W (not 2.5 )
So, if your network module supply 9 W you can connect up to 5 FP RLY 420
National Instruments doesnt recommend to supply external power to this modules.
So If you need to connect more than five RLY 420 you would need to buy another network module. ![]()
Robts no dudo que puedas optimizar los canales de tus modulos para aprovechar el hardware que ya tienes al maximo
Dame mas informacion al respecto para poder recomendarte una configuracion.
Espero que pronto puedas correr exitosamente tu aplicacion
saludos ![]()
‎10-12-2006
11:03 AM
- last edited on
‎03-01-2024
11:01 AM
by
migration-bot
Here is the link where I found the Power requirements of your module
https://www.ni.com/docs/en-US/bundle/374221a/resource/374221a.pdf
‎10-12-2006 09:42 PM
| Robst - CLD |
‎10-13-2006 01:08 AM
Hello Robst
For Systems which need a large number of relays, we prefer using 24vdc external relaye, and FP-DO-401 .
A 8 slot base can oparete up to 128 relays !, and you can use very small relays on "DIN" rail, that keep the system quite compact.
No special power supplay needed .
help ?
