FieldPoint Family
Comparison between cFP and cDAQ
I'm looking for (as much details as possible) a comparisons between compact Fieldpoint and compact DAQ hardware.  I'm trying to decide which hardware platforms to use.
TIA
(6,170 Views)
Compact Fieldpoint is for installed, industrial type applications.  It has a realtime operating system.  The controller runs code to read inputs and operate outputs.  The application can be distributed on an ethernet network.  There are different modules available for different types of inputs and ouputs.
Compact DAQ also has numerous input and output modules.  It is more intended for portable applications.  It connects to your PC through a USB port.  So the code would need to run on the PC
(6,166 Views)
nqn827,
Please take a look at the following documents on each of these platforms for more detailed information.
What's New in NI CompactDAQ
What Is Compact FieldPoint?
Mark
NI App Software R&D
(6,150 Views)
