11-15-2010 10:00 AM
I am doing a research in creating a controlled environment, and i require using labview and NI equipment to control the environment. I am currently using a CFP-1808 as a bank, and using a relay module to connect it to the labview software.
Can you give me detailed information on how i will be able to do that.
regards,
Robert
11-16-2010 09:55 AM
Hi Robert,
Have you had an opportunity to take a look at the cFP-1808 Quick Start Guide? And the Operating Instructions for the cFP-RLY-425? Also the Compact FieldPoint FAQ is an excellent resource.
Hopefully those can get you on your way,
