07-07-2005 09:14 PM
07-08-2005 08:27 AM
Yes, however there is a restriction in that only one IAK file can be active on a computer at a time. Thus both applications, which are calling into the FieldPoint Server, must be using the same configuration file. If the second one tries to use a different file, it will just be ignored.
Aaron
07-09-2005 05:07 PM
07-11-2005 11:34 AM
Hi Jim,
You should be able to acquire different channels on the same FieldPoint system from different applications. What happens when the first application stops working? Do you receive an error? Does the program hang? Does the same behavior occur if you start the applications in a different order?
Please reply back to these questions and I will be glad to help you troubleshoot this issue.
Sean C.
07-12-2005 02:24 PM
07-13-2005 09:12 AM
07-13-2005 10:11 AM
07-13-2005 12:56 PM
07-14-2005 01:49 PM
07-14-2005 05:27 PM
