FieldPoint Family
Callender-Van Dusen Equation
Hi
cn some one help me to slove this equation.
where R0 is the resistance which I read at runtime,
Temperature below 0 degree Celcius.
              RBaseT = R0[1 + A X T + B X Tpow2 + C X Tpow3 X (T - 100 degree celsius)]
Temperature above 0 degree Celcius.
              RBaseT = R0[1 + A X T + B X Tpow2]
where
RBaseT = RTD resistance at temperature T
R0 = RTD nominal resistance at 0 degree celcius
A,B,C are coefficients given
A = 3.18 X 10pow-3
B = -6.02 X 10pow-7
C = -6.0 X 10pow-12
Thanks in advance.
Message 1 of 8
(9,628 Views)
Hi Sujeep,
I know that this equation is used in our FP-RTD-122 modules, but I am not sure why you need this equation solved.  Are you trying to double check the modules output against the equation?
Michael
Applications Engineering
Message 2 of 8
(9,617 Views)
Hello Mr.Michael
         I am reading the resistance value from fieldpoint and converting into temperature by using the formula
          (2.5641 X Resistance value) + 16.59 = Temp in K.        i.e., y=mx+c.
        But this is not accurate value. so I want to make use of the formula provided by NI. Kindly look into the attachment.
Thanks.
Message 3 of 8
(9,602 Views)
This calculation can be made quite easily with the use of a formula node.  The formula node will take in all of the inputs for this equation and will give you a result.  I have attached an example that implements your equation.  I hope that it helps.
Brian Coalson
Software Engineer
Message 4 of 8
(9,558 Views)
Hello Sir,
Thanks for ur reply. But I could not view the attachment becz i am using LabVIEW8.0.
Thanks.
Message 5 of 8
(9,530 Views)
Hi Sujeep,
Here is the VI that Brian wrote but for LabVIEW 8.0.  I hope this helps.
Michael
Message 6 of 8
(9,519 Views)
I think you missed the point of the OP.  He was asking for help solving the equation for T from R!
Message 7 of 8
(349 Views)
I think you missed the date of the last post 🙂
-AK2DM
Message 8 of 8
(343 Views)
